Configures an ESRP domain to track environmental failures.
esrpDomain | Specifies an ESRP domain name. |
priority | Specifies a number between 0 and 254. The default priority is 255. See the following "Usage Guidelines" section for more information. |
No environmental tracking.
Environmental tracking tracks power supply temperature status.
If a failure is detected, the ESRP domain priority steps to the failover-priority value specified. By setting the failover priority to be lower than the normal priority of the domain, it causes the affected domain to go into slave mode.
The range of the priority value is 0 to 254. Setting the priority to 255 configures the switch to slave mode, and to be ineligible to become the master. The switch remains in slave mode even when the VLAN fails over from the current master.
To make effective use of this feature, the normal priority of the ESRP domain must be higher than the failover priority of this command.
The following command enables environmental failure tracking, and specifies that the ESRP priority for ESRP domain esrp1 be set to 10 upon an environmental failure.
configure esrp esrp1 add track-environment failover 10
This command was first available in ExtremeXOS 11.0.
